C-1 - NCRS Discussion Boards
C-1
  • Lee Boyer
    C-1
    Are all front hardtop latches the same on C-1"s
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Yes *NM*
    • Lee Boyer
      Re: Yes
      could you expand a little more? what would they be? I am thinking of buying a n.o.s. pair for my 61.
      • Dennis C.
        • January 1, 1984
        • 2409
        Re: Yes
        Lee: 56 - 62 Hardtop latches, 1 left hand, 1 right hand are all the same. They are of the "short" handle variety. There is a later model with a longer handle that is incorrect and will usually damage the headliner when latched. I will offer that the reproductions I've seen are quite good if the price of NOS stuff gets crazy. There is also a minor difference between hardtop and softop latches. They look almost identical but the mounting surface where it touches the header is a different contour. I would have to check at my shop before trying to describe the hardtop variety.
        • Terry D.
          • May 31, 1987
          • 2691
          Re: C-1
          Hardtop latches are flat at the mounting base, not radiused as the soft top latch. As per the Judging Guide.
          • Kevin Riel
            Re: C-1
            What is the proper length of the front latches for hardtop and softtop for 59? What application do the "improper" longer latches come from? Thanks.
            Kevin Riel
            • Roy B.
              • February 1, 1975
              • 7044
              Re: Yes
              I brought these out in 1992. As you can see the two are different as seen here Fig. 1 shows the bottom side of each handle for soft top and hard top.
              Fig. 2 shows the round bottom soft top handle , while the hard top is tapered at one end and thinker at the other end. Both have short handles.
              Remember the header of the soft top is different then the hard top header so you need to use the right handles . Later 63 to 67 the handles are longer and wont work right. At first the repro's were only made for one top type, then later they found out they were different
              • Tom P.
                • April 1, 1980
                • 1815
                Re: C-1
                The longer latches (just the handle is longer) were the GM replacements.
                I have the replacement latches on my 56 hardtop, and in the latched position, the tip of the handle is so close to the headliner thay you can just barely slip a piece of paper between the handle and headliner. In this case, I guess a miss is as good as a mile, just as long as it doesn't touch and make a hole in the headliner!!!
                • Larry Parylla
                  Re: C-1
                  I noticed the same problem when I got my 62 last September/ October, I slipped a piece of cardboard between the liner and the handle as a temporary fix till I could figure out how to adjust it so as not to put a hole in the liner. After reading this thread I realize I have the wrong length handle.
                  • Dennis C.
                    • January 1, 1984
                    • 2409
                    Re: C-1
                    The difference in the handle length is considerable - my memory is shot, but we are talking upwards of an inch. Again, I'd have to visit my shop to throw a tape measure on a correct one.
                    • Ted S.
                      • January 1, 1998
                      • 747
                      Re: C-1
                      Kevin, These ones on ebay look like the longer version
                      • Kevin Riel
                        Re: C-1
                        Thanks!
                        • Terry D.
                          • May 31, 1987
                          • 2691
                          Re: C-1
                          Dennis
                          Could you do that for us. There are several on E-Bay and elsewhere and it would be nice to know correct length of handle.
