59 PG or not? - NCRS Discussion Boards
59 PG or not?
  • Kevin Riel
    59 PG or not?
    My 59 currently has a powerglide. The engine however has a manual suffix code. I haven't gotten the chance to get the date off of it. I believe it's under the vent tube? The date on the glide is correct for the car. The center section of the rear end is a 62 unit (replacement?). I cannot find the "code" on the rear axle assmbly to see if it is a PG unit. Where are they located at?
    What is the best way to determine if a car was originally a PG or manual car? I'm trying to decide whether the block or the tranny needs to go down the road. The car was built about April 27, 1959.
    Kevin Riel
  • William C.
    • May 31, 1975
    • 6037
    Re: 59 PG or not?
    Look to see it the bracket for the clutch cross-shaft was welded onto the frame, or if any of the clutch linkage is present under the dash.
    Bill Clupper #618
    • Bill B.
      • September 30, 2002
      • 351
      Re: 59 PG or not?
      Kevin, locate brake hose clip on front driver frame side and go back 6 to 12 inch span--check top side for old clutch tower/clutch bracket welds on top outer frame surface. If it feels or looks perfectly smooth I would think this might be a real good indicator that she was an automatic--maybe.
