Heat riser? - NCRS Discussion Boards
Heat riser?
  • chester
    Heat riser?
    The after market repo is diff than the one that is on my manifold. Mine by the way was chemically eaten half way at RediStrip, so my question is does the valve swing down when on the manifold? (The weight) I'm assuming yes because the heat in the coil would then allow it to gradually open(gravity) as the motor heated up. is this right? jc
  • Tom B.
    • February 1, 1994
    • 779
    Re: Heat riser?
    chester,
    Yes, gravity, opens down. Also, be sure to check 68 AIM pages H193 or H208 for the correct "side" it goes on. Best wishes. Tom #24014
    • Tom B.
      • February 1, 1994
      • 779
      Re: Heat riser?
      chester,
      • chester
        Re: Heat riser?
        Thanks Tom just making sure, the riser goes on the Passenger side. The new repo sits differently than the old one, yet the old one I have is in two pieces. Manifolds are on, whoops forgot the dipstick tube(natural finish). jc
        • chester
          Re: Heat riser?
          • Tom B.
            • February 1, 1994
            • 779
            Re: Heat riser?
            chester,
            Sorry about the confusion, I meant which side of the MANIFOLD the counter-balance weight goes on. I, for one, have done it wrong before. Tom #24014
            • Tom B.
              • February 1, 1994
              • 779
              Re: Heat riser?
              chester,
              • chester
                Re: Heat riser?
                the passenger side, and the weight is toward the rear of the car. jc
                • chester
                  Re: Heat riser?
