C 1 T-10 Trans - NCRS Discussion Boards
C 1 T-10 Trans
  • David Lyon
    C 1 T-10 Trans
    I have a 1958 # J58S102838. I will be looking for a re-built BW T-10 while at the Winter Regional next month. My questions - I believe the car was built in early January 1958 - correct me if I'm wrong please - what month build date should I be looking for in 1957 and are there other numbers I should be aware of and where are they located. Question 2: If I'm unsuccessful in locating the transmission in Florida, who is a reliable re-builder/seller you have had success with in T-10's.
    Last question - what is a reasonable price to pay for the transmission with a warranty for parts and labor. Thank you in advance for your reply.
    David
  • William C.
    • May 31, 1975
    • 6037
    Re: C 1 T-10 Trans
    Shou8ld be a T-10 (not a B) case, and the tail housing is both unique and dated. I'll be there, look me up if I can help. They are pricy!
    Bill Clupper #618
    • David Lyon
      Re: C 1 T-10 Trans
      As a follow-up to my initial inquiry concerning the above questions, I thought it would be wise to try to determine what I currently have in the car. It works fine. This is from an old observation, but here goes - the transmission is a 4-speed with a tag # 3915077 and the top of the cover has 3884655 GM. The car had a 305 in it when I bought it so who knows what this beast is. Again, your help is always appreciated, and you all have a Happy New Year!
      David
      • William C.
        • May 31, 1975
        • 6037
        Re: C 1 T-10 Trans
        Muncie 4 speed I believe
        Bill Clupper #618
        • Bill B.
          • September 30, 2002
          • 351
          Re: C 1 T-10 Trans
          I found two 58 transmissions several years ago that would work for my May 1958 project. One was going for $3000 and the other for $3600--and I am not sure they were rebuilt. I suspect a correctly dated T-10 in this early period is not a cheap affair. By the way, I did not buy either and will live with my muncie until some future luckier day comes along.
          • Mike M.
            • May 31, 1974
            • 8386
            Re: C 1 T-10 Trans
            Bill: consider yourself lucky in that you need a 58 T-10(2-3K$) vs a 57 t-10 which fetch 5 to 10( if you can rely of asking prices) .mike
            • David Lyon
              Re: C 1 T-10 Trans
              Thanks to all for your information. This will take a lot of hard thought on my part in deciding to purchase if I can find one. I did return e-mail to those who replied by e-mail, but it all came back this morning. I have resent the e-mail and hope you'll get my reply. Again, thanks for your input and if the transmission I have is a Muncie, can anyone tell me what type and year of vehicle it fits.
              Again, thanks!
              David
              • Loren L.
                • April 30, 1976
                • 4104
                I have seen an early '58 (200)) with a
                July 57 assembly date as original equipment - told the owner that he could go sample the 1957 market for some $$$, but he declined as he had owned the car 35 years. Doctors can afford to do that.......
                • Loren L.
                  • April 30, 1976
                  • 4104
                  # above should be 2000+ *NM*
                  • Bill B.
                    • 351
                    Re: C 1 T-10 Trans
                    David, following website may give you some helpful info
                    www.5speeds.com/muncie2.htm
                    • David Lyon
                      Re: C 1 T-10 Trans
                      Thanks, Bill. The site will be most helpful. Happy New Year!
                      David
