1982 Rear Window Defog Wiring - NCRS Discussion Boards
  • Chris Kelly#29320
    While attempting to troubleshoot a rear window defog problem I discovered that the wiring diagram in the 1982 Corvette shop manual st-364-82 section 9-9 fig. 9-8 was incorrect or my '82 is missing the timer relay. Does the '82 non collector cars have this timer relay? If so were is it located? The shop manual shows the relay located under the armrest but I have yet to find it. This car is very original so I have to believe that the manual is in error.
    If the manual is in error were can I find the correct wiring diagram for the '82 defog system?
    Also it appears that the rear defog switch may be hard to find. Any good suppliers to contact? I have not been to my local Chevrolet dealer yet.
    The rear defog worked last winter but does not appear to be working now.
    Any assistance will be appreciated.
    Chris Kelly
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 1982 Rear Window Defog Wiring
    Chris,
    On E-bay. Go to 2451391029
    Good Luck,
    JR
    • Chris Kelly#29320
      J.R.
      Thanks I'll check it out.
      I believe that I found the correct schematic further back in the shop manual in section 8a-57. This schematic represents what I have and shows the timer built into the switch.
      The assy manual, upc 12h sheet 28 or page 560, also does not show a relay in the wiring.
      Time to check ebay.
      Chris Kelly
