over flow tank and resistor - NCRS Discussion Boards
  • Roger Konkel
    On my 67/400hp coupe there is a bracket for a over flow tank on the fender by the battery. It should not have an over flow tank, am I correct? I am also missing the resistor and bracket that plug into the regulator on the fender. Where can I find one?
    • 43221
    Re: over flow tank and resistor
    Roger-----
    Yes, a 1967 Corvette with L-68 engine did not use a radiator supply tank. However, all 1967 small blocks and L-88s DID use such a tank. The only reason that I can possibly concieve of for a bracket being on your L-68: the car was originally a small block (or, an L-88) and someone converted it to an L-68. Many 1967 Corvette small blocks have "grown up" and become big blocks over the years.
    Big block 1967 Corvettes not built with the supply tank bracket as an "unused appendage".
    The voltage regulator RFI condensor is long-since GM-discontinued. I don't know if a reproduction is available, or not.
    • Stephen L.
      • May 31, 1984
      • 3158
      L.I. Corvettes has replacement Condensers, however they do not have the part number on them.
