C1 59: Radiator seals - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12740
    Colleague Restorers,
    Just bought myself some radiator seals to install my new radiator properly. I'm just wondering what the correct procedure is to install the radiator using these seals (are they glued and if so what type of glue should be used). I've received 2 side seals, 1 bottum seal and some triangular top seals.
    I also received the needed drain cock and rubber drain hose. The lower shroud (still to be paint prayed) with the needed bolts (no nuts). I still need the proper bolts and nuts for the upper shroud (which itself is still usable), which are diffecult to find over here (due to the non-metric measures).
    I have to reuse the old upper hose since it seems almost impossible for me to get the right hose (I have a straight thermostat housing). The new lower hose seems to fit just fine.
    greetings and merry Chrismas,
    Rob Musquetier.
    The C1 1959 Corvette Restoration Project
    Rob.
    NCRS Software Developer
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 59: Radiator seals
    Rob,
    I just use 3M weatherstrip adhesive to glue the seals in place. I usually use the black adhesive for a neater look, but the factory did not care about such subtle nuances and just often slopped the yellow stuff all over the place.
    Regards, John McGraw
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Rob - I believe the two triangular seals are placed at the bottom front corners of the radiator, glued to the radiator support. The other single seal goes at the bottom of the rad, glued to the support - it will touch each bottom corner seal. I agree with John on the glue issue. I may be wrong, but I don't believe your car uses any radiator side seals. (Check the Judging Guide and/or the AIM. Best, Dennis
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12740
        Dennis,
        Indeed I've also got 2 side seals with 3 small holes in them. If not needed I leave them out...
        greetings,
        Rob.
        The C1 59 Restoration Project
        Rob.
        • Loren L.
          • April 30, 1976
          • 4104
          Dennis is correct - side seals before
          mid-1962 are a marketing tool of the evil kingdom.
            • May 31, 1974
            • 8385
            Re: Dennis is correct - side seals before
            Evil kingdom??? Had too much spiked egg nog?? have a super holidays. mike
            • Dick W.
              • 10483
              Mikie, most of the barristers that I know prefer Wilkes County's finest brandies, apple or peach. And large quantities Judges have a taste for it too.
              Dick Whittington
              • Loren L.
                • April 30, 1976
                • 4104
                I AM a plot owner in Lynchburg..... *NM*
                • Dick W.
                  • 10483
                  Re: I AM a plot owner in Lynchburg.....
                  Damn! The neighborhood has gone all to hell
                  Dick Whittington
