Torque for spindle & flange nuts - NCRS Discussion Boards
  • Jeff A.
    • December 1, 2001
    • 95
    This should be an easy one, although I can't find it in the AIM. What torque should go on the spindle nut (rear) and on the flange bolts holding the half shafts on ? Thanks and happy holidays.
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Torque for spindle & flange nuts
    Spindle nut: 100 ft-lbs. Do not loosen--go to next castellation if necessary.
    Flange bolts: 40 ft-lbs
      • 43222
      Joe and Jeff-----
      The flange bolts (i.e. the bolts that retain the half shaft u-joint flange to the spindle flange) are torqued at 75 ft/lbs.
