Color behind eyebrows and front bumpers of C1? - NCRS Discussion Boards
  • Kevin Riel
    What color should be inside the eyebrow opening on the front of a C1? Also, what color should be behind the front bumpers? I've seen cars with the body color in these positions, or some with either gloss or flat black here. Which is correct?
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Color behind eyebrows and front bumpers of C1?
    eye brow openings semi gloss black ( black out) everything else body color.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Kevin - If I may take the liberty of assuming you are refering to a 58/62 C1, paint the frontal vertical portion of the outer grille ports w/Krylon 1613 & nothing more. Do not wrap it around the side, do not paint any other portion that is not absolutely vertical. What we are really dealing with here is a bogus factory wanna-be air inlet look-a-like. Kind'a like the '58 bogus hood.
      • Kevin Riel
        Ok... so it sounds as though the "fake air ducts" should be semi-gloss black, but the area behind the front bumpers should be body color? Thanks for the responses.
        • Dennis C.
          • January 1, 1984
          • 2409
          Kevin - Vertical area behind front bumpers is semi black, but it stops. Body color behind bumpers as they round in body channel and head back toward wheel well opening. Black only in front vertical depressed area of port.
          • Kevin Riel
            Ok... I think I understand. I just mask to a point where it starts to make the bend?
            • Dennis C.
              • January 1, 1984
              • 2409
              10-4 Good Buddy *NM*
              • Clare Carpenter
                Make sure to check paint compatibility....
                before spraying, just to be on the safe side.
