C3 - 1971 Will This Size Tire Fit My Vette???? - NCRS Discussion Boards
  • Peter B.
    • July 31, 2000
    • 155
    Looking to get BFGoodrich TA Radials. I was looking at 255/60/15 but was told that on a '71, it will rub on the outer front well.
    I was then recommended by someone in NCRS to go with 245/60/15. Those will not rub.
    Any other input you can help me with? I plan to go with the 245/60/15.
    • 43221
    Re: C3 - 1971 Will This Size Tire Fit My Vette????
    Peter-----
    I always recommend the 245-60-15. I have used this size for years with no interference problems, whatsoever. I've heard conflicting reports on the 255-60-15. Some folks seem to use them without modification to the fenders and others have had problems without, at least, slight fender modification. I think that the problem is that they are very close to fitting, so slight differences from car-to-car is waht makes the difference. For me, this indicates a fitment that is way too close, even if the tire appears to fit ok upon installation. So, personally, I would never use a 255-60-15, even if I were using the tires on a 1970+ with fenders which are somewhat different than my 69.
    • Peter B.
      • July 31, 2000
      • 155
      Do you recommend 245 in the front and 255 in the rear or go 245 all around?
        • 43221
        Peter------
        I recommend 245-60-15 at all four corners. I wouldn't even consider using 255-60-15 on the rear only, even if they would fit without problems.
        • Peter B.
          • July 31, 2000
          • 155
          I will be replacing 225 70 15 Firestones. On Tirerack, their overall Diameter is 27.3inches. The overall diameter of 245 60 15 BFG's is 26.6 inches. that is a .7 inch difference in Diameter.
          Do you feel it will look good with less wheel well filled in?
          • Warren F.
            • December 1, 1987
            • 1516
            For your information, Goodrich Euro T/A 265x50x15 size tires will also fit. I have had four sets of tires on 3 '70's & 1 '71 Corvette, all fit with no modification to wheel wells.
              • 43221
              Peter-----
              I think that it will look fine. In my opinion, the 225-70-15 look to be too big in the wheel well. I realize that the 225 is close in diameter to the original F-70-15 size. However, the tread width and general configuration of those tires were different. To me, the 225-70-15 look "oversize" in the wheel well regardless of the fact that their diameter is close to the original.
                • 43221
                Addendum
                Peter-----
                One other thing. The OD of the original F-70-15 was 26.95". So, the 225-70-15 is actually 0.35" LARGER in OD than the original tire. The 245-60-15 is 0.35" SMALLER in OD than the original tire. The smaller OD helps "compensate" for the extra tread and section widths of the 245-60-15 tire and prevents fender/tire interference.
                The 255-60-15 is 27.05" OD. However, it has a section width of 10.24" compared to the 9.76" section width of the 245-60-15, 8.98" section width of the 225-70-15 and 8.95" section width of the original F-70-15.
                The 255-60-15 has a tread width (depending on tire make/model) of 7.7" compared to the tread width of 7.4" for the 245-60-15 (depending on tire make/model), 6.7" for the 225-70-15 (depending on tire make/model), and 6.5" for the original F-70-15.
                When you combine all of the larger dimensions of the 255-60-15 over the original tire size, you end up with a tire that, overall, is considerably larger than original. Therein the fitment problems are created.
                When the 255-60-15 tire size was added as an option beginning in the 1978 model year, there were TWO changes that were made to accomodate these tires. One change involved a St. Louis modification to the 78+ style fender lips.
                Corvette trivia question: can anyone tell me what the OTHER change was?
                  • 11643
                  Re: Addendum
                  Joe,
                  Didn't they also change the front lower control arm bump stop (I think that's the name of it) to prevent interference?
                  Patrick
                    • 43221
                    Re: Addendum
                    Patrick-----
                    You got it!
                      • 11643
                      Re: Addendum
                      So is my reward a visit to your parts place heaven when I come out to Monterey in March? How about meeting me for dinner - and YOU pick the restaurant!
                      Patrick
                        • 43221
                        Re: Addendum
                        Patrick-----
                        Sounds good to me. We couldn't do much better than the place we were at the last time, but for the sake of "variety" I think I could come up with something "new and different". Let me know ahead of time when you'll be in Monterey.
                        • Dan Tewell
                          Re: Addendum
                          Joe, there must have been more than 2 changes then. The cars with 255-60-15 had the rear inner edge (where the rocker molding atatches) cut back at an angle so the tire wouldn't rub. This change also required a shorter rocker molding. There were actually two different part numbers for 78 fenders and rocker moldings.
                          What do I win?
