harmonic balancer - NCRS Discussion Boards
harmonic balancer
  • roland verrico
    harmonic balancer
    Does anyone know the GM part number for a harmonic balancer for a 1965 327CI -250H.P. could it be 2712? Thanks for any help.
    • 43236
    Re: harmonic balancer
    Roland-----
    First of all, "2712" would not be the part number for a GM balancer, original or not. Otherwise, it depends whether you're talking about a current SERVICE balancer or an original PRODUCTION balancer. The original PRODUCTION balancer for you application was GM #3861968. This was a 6" OD balancer of "stepped" configuration, with the smaller 4-1/2" OD "step" on the FRONT. It was available in SERVICE until November, 1965.
    Since June, 1971, the SERVICE part number for a balancer for your application has been GM #3896904. This is a non-stepped balancer of 6-1/8" OD and 3/4" thickness. It remains available from GM to this very day. Its configuration is significantly different than the original, but it will SERVICE your application perfectly.
    • roland verrico
      Joe, Thanks so much ,thats just what I needed.
