69 fasteners - NCRS Discussion Boards
69 fasteners
  • KELLY THEAKER
    69 fasteners
    On the grill moulding/chrome- was a pal fastener used or a push on clip?
    on the headlight support housing - . the park/turn signal attatch to the support a # 10 -24 is used but is it a phillips short or a hex head.
  • George D.
    • August 31, 2000
    • 225
    Re: 69 fasteners
    Kelly
    Pal nuts were used on the chrome grill bezels. I'm not sure which part of the headlight support you are referring to with regard to the park/turn signal.
    George
    • KELLY THEAKER
      Re: 69 fasteners
      there is a support that is fastened with 2 -1/4 " bolts on the air dam and the top of this support that the plastic grill that houses the turn signal attatches to. right at the top of this support is a small hole that is used to attatch this bracket to the headlight housing support. it is a #10-24 . it is this bolt or screw that i am asking about is it a phillips or a hex?
      • George D.
        • August 31, 2000
        • 225
        Re: 69 fasteners
        Kelly
        If your referring to the single screw that holds the parking/turn signal bracket at the top where it attaches to the headlight support it is a self tapping hex head screw. I'm not sure of the size, but I think it is smaller than a 10 x 24.
        George
        • KELLY THEAKER
          Re: 69 fasteners
          are you certain that it is self tapping , i have put both in with my fingers #10-24 , ?
