53-55 Gas Sender - NCRS Discussion Boards
53-55 Gas Sender
  • Roy B.
    • February 1, 1975
    • 7044
    53-55 Gas Sender
    In 1990 I wrote about the C1 53-55 Corvette fuel sender and I'm posting it here to help owners again.
    If careful you can pry the side cover off to clean the rheostat , or the float arm button which causes the gage to jump around . If the float arm button has wear or worn down , by bending it and giving it more tension will correct the contact and give a more steady reading.Two things usely cause your bad reading.
    1.You loose ground contact in your harness or the float arm button has worn down.
    2. The brass float may have a pin hole , filling it up with gas.
    Again E-Bay is a good place to find a truck sender from 53 to 54 which is the same as the 1953 to 1955 Corvette.
    The cleaning can be done on all units from 53 to 62.
    Yes the 53 to 54 are 6V but the sender is "neither" and will work in the 12V 55.This is not hard to do and can save your original sender.
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 53-55 Gas Sender
    Roy: had forgot about your 1990 sending unit article for the 53-55 and about 3 years ago, i needed a new sending unit for our 55 vet. seems to me corvette central had them for a reasonable price. i got one from them(i believe that is who supplied it) but haven't fired the ole 265 up yet. Seems like it was about 50-60 frogskins. came in looking like config of the original(which was trash and un-rebuildable). Once i fire the 55 up, will let you know if the repro functions. mike
    • Roy B.
      • February 1, 1975
      • 7044
      After I wrote the article in Straight Talk then many suppliers offered them must have read my article and bought then up from dealers. And like the Delco shocks I wrote about in 1988 that G.M still sold them original for 53 to 62 at $21.00 each. Then suppliers sold them for $150.00 each.You may still be able to get them from dealer's back room old stock.
      #3192963 =rear and #3192095 =fronts.
      Then buy the repro guards I again wrote about in 1989.Because I copyed the whole page , may be those newer 56 up Corvettes with long bolt fuel pumps need a rebuilt kit, so I left it on.
      Only vary OLD guys like you member #14,remember my Articles! these new kids in thier 50's and 60's don't. Ha! Ha!
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12738
        I must be a very greenish then with my 36 years ;-)
        The C1 1959 Corvette Restoration Project
        Rob.
        NCRS Software Developer
        • Dave Suesz
