C1 door lock knob - NCRS Discussion Boards
C1 door lock knob
  • Kevin Riel
    C1 door lock knob
    I know this sounds stupid, but how do you get the inside door lock know off of a C1? I know there is a clip that fastens it, but I can't figure out where and how you get it off. Thanks.
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C1 door lock knob
    Kevin: check out my post just above your question. regards, mike
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Kevin - In spite of how confused Mikie is, note that window crank and lock knob do not share the same removal tool - for reasons that totally escape me - the dimensions of the slot are different. Often, with some patience, you can remove the lock knob with a tiny screwdriver or pocket knife. Just need to back out the "C" clip.
      • Bob Simard
        C1 door lock knob clip
        Try running an old terrycloth towel behind the knob. The cloth will snag the end of the clip and peel it off. Or at least that was the story that I heard.
        • Mike M.
          • May 31, 1974
          • 8385
          Dear Dippy: in spite of how confused i am thruout the day and evenings, i stand by my contention that the tool i use to remo, I've inside door handles and window cranks is the very same tool i have successfuly used to remove the inside door lock knob. mikie
          • Dennis C.
            • January 1, 1984
            • 2409
            Mikie: Stop using Edsel lock knobs... *NM*
            • Mike M.
              • May 31, 1974
              • 8385
              Re: Mikie: Stop using Edsel lock knobs...
              They're Edsel knockers, not knobs, fool.
              • Ray C.
                • June 30, 2001
                • 1132
                I purchased a small set of pick tools. They look like small screwdrivers with very thin shafts and points at different angles and curves. I was able to hook on to the horseshoe clip and remove if with out damaging the side panels.
                Ray
                Ray Carney
                1961 Sateen Silver 270-HP
                1961 Fawn Beige 315-HP
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  Just for fun, I cut plastic lids from Folgers coffee cans for at least 2 items. One is screwing with door/lock knobs, the other is dash pads. I use these as shields for insurance that I won't violate the door/dash panel vinyl material. It has turned out to be a no cost insurance program. With one of these lids cut and well placed, you can save save more than the lizard in the Geico ads. DC
                  • Dennis C.
                    • January 1, 1984
                    • 2409
                    Of course, as you know, I love knockers - whatever they are...
