C2: N11 exhaust PN# 3845737 - NCRS Discussion Boards
  • Dan Pepper
    I just came across the passenger side half of an NOS N11 system, but the PN# is one digit off of what I would expect it to be. It's debossed PN# is 3845737 with the usual GM stamp and date coding. I would expect it to carry a PN of, 3845736 (or 735 for the driver's side). The config looks the same, but not sure what the difference is. Would the General issue a PN just one digit off of another part number if the part isn't different?
    • 15678
    Re: C2: N11 exhaust PN# 3845737
    I think the p/n you see is for the muffler alone. The service and AIM numbers
    are for the assembly which includes the muffler and rear exhaust pipe section.
    • Dan Pepper
      Duke,
      Since N11 exhaust only came a "one-piece" unit, so to speak, why would GM have a separate PN for just the muffler? The N11 muffler (without pipes) was never available as a stand-alone part, right?
      • Joe R.
        • July 31, 1976
        • 4551
        Dan,
        All the off the road exhaust I have ever had in stock had the part number painted on the mufflers 3845735 and 3845736. I have a 1973 parts book and 3845737 is not listed.
        JR
        • Dan Pepper
          I have a set of NOS N11 on my '66 BB coupe, and the PN's and date code info is debossed on them - there is no evidence of ink stamps etc. As for the unit listed above, I looked through the tech board archives and found one other reference to PN 3845737. The post referred to a 3845767 PN ink-stamp on an N11 muffler, in addition to the 3845736 debossed PN. No additional info was supplied about the succession of PN's in this posting, although the unit had what appeared to be two separate welded-on hangers instead of just one. The unit I'm referring to has only one C2 type hanger mounted on the aft end of the muffler. I'd be happy to email you a pic if you are interested in seeing it for yourself.
          • kenrobb
            I have a set on my 65 that I purchased from GM in 1984. They have the P/N 3845735 and 3845736 on them. They are also are embossed with 1 2 101 4 A.
            Then I have a set I purchased from GM in 1996 before they were discontinued. One has the P/N 3845737 and 2 1 270 4 on it. The other one does not have P/N, but has 1 2 191 1 on it.
            From this I would say GM had someone else make a run of N11 exhausts in the 90's.
              • 15678
              Yes the "off road system" was available only as an assembly that consisted
              of the muffler and rear pipe section, but both the muffler and pipe probably had their own part number. They just weren't available separately through
              service parts.
              Joe can probably shed some light on this subject.
