'67 rear caliper steel brake lines - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I am trying to install the steel rear caliper brake lines in my '67. They don't seem to fit very well. Neither end will connect unless I bend them quite a bit, let alone both ends fitting. Do these normally require quite a bit of bending to fit in place and connect properly at both ends. You would think they would be pre-bent correctly. They are from Classic Tube.
  • Dick W.
    • 10483
    Re: '67 rear caliper steel brake lines
    Some of the vendors' lines are not bent real close to original. Gentle persuasion usually will take care of the mis-alignment.
    Dick Whittington
    • Rob A.
      • December 1, 1991
      • 2126
      I took the rear stabilizer bracket off and did some minor bending, and they fit fine now....Thanks
