AC Delco Spark Plug suffixes - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Can someone refresh my memory on meaning of the various N, R, T, S, L, X's following the Size (eg. 4 = 14mm) and heat range (eg. 2=cold, 6=hot).
    TIA
  • Dave S.
    • August 31, 1992
    • 2925
    Re: AC Delco Spark Plug suffixes
    Wayne,
    N = Big Block
    R = Resistor
    T = Tapered seat as in the later peanut plugs(around 70 and up)
    S = Extended Tip
    Not sure what L and X mean.
      • 15679
      From my '94 Vintage AC-Delco Spark Plug catalog.
      N = 3/4" reach, 3/8" thread length
      R = Resistor (sport vehicle plugs)
      T = taper seat shell design
      S = extended tip or 7/8" moderate long reach or 23/32" long reach
      X = wide gap (HEI)
      XL = 3/4" reach, fully threaded
      • Jeffrey S.
        • May 31, 1988
        • 1882
        Wayne:
        N= extra long reach (3/4 inch reach with 3/8 thread length); R=Resistor; T= tapered seat (no metal gasket is used); S= extended tip; L=long reach- 7/16 in.; X=special gap (usually wide gap).
        Hope this helps.
        Jeff
