CAN'T REMEMBER WHERE THESE CLIPS GO - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I have 5 clips, same shape as the one on the L hood latch for the washer hose, but about twice the size, rubber coated. Where do these go? (I'm about to put the body on the chassis and haven't needed them yet).
  • Joe R.
    • July 31, 1976
    • 4551
    Re: CAN'T REMEMBER WHERE THESE CLIPS GO
    Rob,
    Could those clips be the ones under the nose that hold the wiring harness out of the way of the headlights?
    Just as shot in the dark as you have not said what year Vette we're talking about.
    JR
      Rob -
      Don't know about "twice the size of the one for the washer hose", but there were six of the #3827371 vinyl-coated push-on clips used on 67's - one on the left hood latch for the washer hose, one on the left side front of the radiator support for the headlight harness, two to retain the antenna cable to the back side of the dash crossbar, and two to retain the courtesy light wires to the back side of the dash crossbar below the glove box.
      • Rob A.
        • December 1, 1991
        • 2126
        I'm working on a '67 the wiring harness clips are already installed. However, the radiator support is not.
        • Rob A.
          • December 1, 1991
          • 2126
          I have the ones you are referring to. These are actually twice the size of those. It's been awhile, but I can't believe I would taken the time to rubber-coat these if I didn't have originals to copy. Guess I'll either find out as I continue or have "extra" parts when I'm done.
          • kelly theaker
            battery - trans tunnel?
            • Page C.
              • February 1, 1979
              • 802
              Hi Rob,
              There are 5 or 6 Rubber coated clips that hold the rear wiring harness up to the tail light studs.
              Just a guess
              Page Campbell
              • Rob A.
                • December 1, 1991
                • 2126
                I already installed those........thanks
                • Rob A.
                  • December 1, 1991
                  • 2126
                  Nope, they're in already....this are meant to cip on to the edge of something, like the one on the hood latch and the radiator support that holds a wire.
                  • Rob A.
                    • December 1, 1991
                    • 2126
                    John, I know exactly which clips you are referring to, these are larger. It's been so long, I just can't remember exactly where they go.
                    • kelly theaker
                      are they shaped in an s" with a barb ? show a picture if possible , these guys a re sharp
                      • Rob A.
                        • December 1, 1991
                        • 2126
                        How do I show a picture through using the discussion board? (no, there is no barb, it is meant to clip onto an edge.
                        • kelly theaker
                          not exactly sure , maybe someone could answer , you may only need a digital camera or you may need a scanner, someone will pick up here
                          • Larry S.
                            • August 31, 2000
                            • 356
                            Rob email me a picture and I will post it for you.
                            Have you gone thru any of your supplier parts catologes and seen the same clips maybee you could determine that way.
                            • Terry F.
                              • September 30, 1992
                              • 2061
                              Just guessing, but they sound like the retainers/c-clamps for the battery cable that ran under the drive shaft hump. I am uncertain of what year car you are working on though. Terry
