C2 BB Aircleaner vs. SB - NCRS Discussion Boards
  • Steve Miller #39713
    Does the big block air cleaner base drop the filter element lower then the small block base? This assumes the base will be set on the same Holley 4 barrel.
    • 43221
    Re: C2 BB Aircleaner vs. SB
    Steve-----
    No, it does not. The basic stamping for the bases is the same. The differences lie in the configuration/angle of attachment of the attached PCV tubes.
