Heater Seals 67 - NCRS Discussion Boards
Heater Seals 67
  • John M.
    • January 1, 1998
    • 813
    Heater Seals 67
    Does the thicker foam seal, the big U shaped one go between the heater box and the core or the core and the firewall? I have two of the thinner seals which could be used on the inside and outside of the firewall. I know one is required on the outside. Thanks for any help.
  • Geoff C.
    • May 31, 1979
    • 1613
    Re: Heater Seals 67
    Sir,
    That foam seal slips over the 4 threaded studs, then the steel core support plate with core mounts over the same studs. The two seals that are identical mount on either side of the firewall.
    The order is as follows:
    Inner box
    Foam seal
    Metal core plate
    Black sponge seal
    Firewall
    Black Sponge seal
    Outer Box.
    Some 1963 only use 1 black seal. ??? Don't know why.
    Geoffrey Coenen
    PS I just noticed my diagram is wrong.
    • John M.
      • January 1, 1998
      • 813
      Re: Heater Seals 67
      Geoffrey,
      Your diagram and the shop manual and the AIM are different. That's why the question. Thanks for the clarification.
