'03-upGM F/s pickups and suvs - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8383
    Found a source for the High Beam Headlite Relay Kit which whenn installed will allow for all four lights to work when High Beams is on. Stylinconcepts.com . $59.90 total. REALLY MAKES A DIFFEERENCE FOR OLD EYES> mike
  • Clem Z.
    • January 1, 2006
    • 9427
    you can do the same thing for $4.95 and some wire
    just buy a fog/driving light relay at the auto parts,trigger the relay with the hi beam headlight wire and run a 12 ga fused line from the red terminal in the altenator thru the contacts on the relay to the low beam wire. that way you get a full 14.5 volts to the low beams. if you use a digital volt meter at the headlights you will see that that there is only 11 volts because of the resistance of the wire. i have been doing that since the 4 head light systems can into being.
    • Mike M.
      • May 31, 1974
      • 8383
      Re: you can do the same thing for $4.95 and some w
      $59.90 minus 4.95 = 5 1/2 cases of the beast. thanks clem. mike
      • Clem Z.
        • January 1, 2006
        • 9427
        you can send me a case. *NM*
        • Dick W.
          • 10483
          Re: you can send me a case.
          The way to most men's heart is thru their stomach, the way to Doc's is thru his pocket book. That leaves move frog skins for the "beast":D
          Dick Whittington
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            Yes, Frogskins be cool... *NM*
