As with any restoration you find out many things when you receive new parts. i got my new bolts to put on the new (rebuilt original) water pump there was three bolts (same size) and a bolt/stud. Hummm, I marked the ones i took out ant ther was no stud there??? Where does the one stud go if you look straight at the motor? and what's if for?? Pully? bracket? thanks jc
H2O 3 bolts 1 stud?
Re: H2O 3 bolts 1 stud?
Chester,
You didn't say what year and engine you're talking about, but my '75 L-48 (small block) has three bolts and a stud holding on the water pump. The stud is on the driver's side, upper hole (I believe), and holds my alternator brace.
Bill Baird- Top
Chester,
Bill Baird- Top
