67 BB RADIATOR, SUPPORT, SHROUD INSTALLATION - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I'll be putting the body on my '67 chassis soon. It's been so long since I took it apart, I can't remember in what sequence I removed the radiator, support, shroud, fan, etc. What is the easiest sequence for installation of these items.(I think I remember removing the support and radiator as one)
  • Joe R.
    • July 31, 1976
    • 4550
    Re: 67 BB RADIATOR, SUPPORT, SHROUD INSTALLATION
    Rob,
    Since you have the support, radiator and shroud already out of the 67, I would assemble these three before putting it back in the 67. Some restorers then put the assembly in the body and drop the whole body assembly on the chassis. I don't do it that way as it makes it a little heavy in the front. I do the body drop and install the shroud, radiator and support as an assembly into the body on the frame. Then install the lower radiator hose and the fan blade with clutch attached. This works for me and lessens the possibility to dinging up the radiator trying to get the shroud in past the right upper control arm. Good luck and go easy. Let us know how it works out.
    JR
    • Rob A.
      • December 1, 1991
      • 2126
      Thanks, that sounds good, I'll try it that way.....
