C1 ('62) Speedometer and Gauge Cluster - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    I want to remove the speedometer so I can send it out for repair. Also need to replace or repair the ammeter. Do I need to take out the whole speedometer/gauge cluster? Or, can these individual items be removed while leaving the cluster in place?
  • Ed Jennings
    Re: C1 ('62) Speedometer and Gauge Cluster
    You can remove the ammeter/oil pressure cluster from the main cluster with some difficulty, but it is a pointless, since the cluster has to come out to remove the speedometer. The cluster really isn't all that difficult to remove and there are very clear instructions in the ST12.
    • Eric Eade
      Chris, Watch your wiring as you lift off the housing. When I pulled mine, I had the problem of light bulb wires snagging and pulling. I ultimatly tagged the wires before I pulled it off. good luck, Eric
