c2 brake line - NCRS Discussion Boards
c2 brake line
  • Steve Pettit
    c2 brake line
    Hello everyone,
    Is there any way, short of lifting the body, to replace the brake line on a 66 bb?
    Steve
  • Steve Pettit
    Re: c2 brake line
    Probably should add that it is roadster
    • Michael S.
      • April 1, 1987
      • 364
      Re: c2 brake line
      All the brakes lines can be replaced without lifting the body including the front to rear line on the left frame rail. It runs along the inside bottom of the left frame rail. You will have to "fish" the front to back line through the center cross member but just look at how the original line is currently run. The hardest part is getting a wrench on the brass rear block near the left rear wheel.
      Mike Strinich
      #11202
      • Steve Pettit
        Re: c2 brake line
        Thank You Mike,
        I'll get my pole and start fishing.
        Steve
        • Larry S.
          • August 31, 2000
          • 356
          Re: c2 brake line
          Steve check the archive on this I posted on it myself.I did mine and thought it was almost nearly immposible to do.Yes I did it up on a lift but was starting to think I made a mistake taking the old one out.The first clamp toward the front between the frame and the floor pan was almost impossible to remove and the only way I was able to re install that clamps bolt was to cut the bolt down to about 3/8 of an inch long.Good luck and for sure check the archives before you start
