Metal Stripping - NCRS Discussion Boards
Metal Stripping
  • Robin Corter
    Metal Stripping
    I need to remove the metal stripping around the windows on a 1963E corvette. I was wondering if there is a special tool or if you all can give me sggestions on the best way to remove the stripping.
    Thank you
    Robin Corter
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Metal Stripping
    The metal trim is held in place with a number of clips. There is a special tool which will release the clips. I recently purchased one at an auto body supply store. As these are only used on older cars they did not have the tool in stock but were able to order it for me. It was about $10.00
    • Frank H.
      • May 22, 2013
      • 148
      Re: Metal Stripping
      the tool is a flat sheet metal hook or somtimes double hook I've seen them at advanced auto parts and at carquest in the HELP line of tools and parts where I found some plug wire looms for the 67s valve covers just like the old ones.
      FH
      I,ve also seen a guy clamp a small allen wrench in a small vice grip and unhook them!
