Clutch Replacement - Question Re Threadlock - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    Replacing the clutch in my '62. Flywheel and clutch are to be balanced separately and together. Getting ready to put it all back together. The manual doesn't state, but I'm going to use blue (medium strength) Threadlock on the flywheel and clutch bolts. Never used this stuff before. (Only recently started using a torque wrench.) Do you slather the Threadlock all over the bolt like antiseize? Or, just use a dab? (Extra credit trivia question: What was "just a dab'll do ya.")
  • Nicholas L.
    • November 1, 1982
    • 341
    Re: Clutch Replacement - Question Re Threadlock
    Brylcream.
      • 15606
      I believe there are some directions on the bottle, but IIRC thread lock only needs to be applied to about three turns of the threads.
      BTW: the same is true of anit-seize. More is NOT better.
      • Dick W.
        • 10483
        Terry, even the manufacturer recommends as you have, and has done so for at least 35 years, just a drop or so. Same for Neverseize, just on the first couple of threads, not dripping off.
        Dick Whittington
          • 43238
          Chris-----
          I definitely recommend the use of Lock-Tite on the clutch and flywheel bolts. As others have described, only a very small amount is required. However, another really important thing is that the threads of the bolts and the threads in the crank flange and flywheel be ABSOLUTELY free of any oil, grease, or other contamination. I recommend cleaning the threads with a thread chaser and then cleaning everything SCRUPULOUSLY CLEAN with brake cleaning solvent.
          • Dick W.
            • 10483
            Good point Joe that we all missed. Loctite sells a cleaner/primer.
            Dick Whittington
