has anyone had a lot of experience with the A post area ? on the C3s the questions are - #1 did they use a stuubby self tapper for the stainless attatch?
#2 the moulding the weatherstrip fits into has an elongated base and middle hole for adjustment , is the top or third hole supposed to be elongated also ? because the windoww when wound up is missing the clip and going inboard, the door is adjusted well and at the limit,
#3 the caulking or weatherstrip goo used sandwitched in between all of this buildup is?
I have the mouldings all installed with weatherstrip and mouldings and the weatherstrip moulding is angled in more at the top than at the bottom . is this normal ?
