C2 differential vent - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    Is there supposed to be a gasket or O-ring on the plastic vent that taps into the case?
    Steve
  • Craig S.
    • June 30, 1997
    • 2471
    Re: C2 differential vent
    No - it drives in directly with no O-ring.....Craig
    • Craig S.
      • June 30, 1997
      • 2471
      Also - some of the earlier vents were not plastic but steel. I have several examples of covers with this breather vent. I believe the 67 up changed to plastic, but somewhere in 66 there may have been a transtition. I think this change was at the same time as the cover that ends in 75 for the last two digits of the casting number (seems like it is 1275 or 1375 if I recall for the last 4 digits)...Craig
      • Steve D.
        • February 1, 2002
        • 990
        You're right on; the casting # is 3871375. The car is 63, but the rear is 67.
        Steve
