'67 CLUTCH FORK SPRING CLIP & RIVET - NCRS Discussion Boards
+ More Options
Posts
  • Rob A.
    • December 1, 1991
    • 2126
    Can the spring clip and rivet for the clutch fork be purchased at a "normal" auto parts store, as opposed to ordering from Long Island, Paragon, etc?
    • 43232
    Re: '67 CLUTCH FORK SPRING CLIP & RIVET
    Rob-----
    1) I've never seen this part for sale in an auto parts store;
    2) You can buy one from GM under GM #12337938;
    3) I wouldn't even consider trying to replace this spring. If it needs replacing, I'd replace the whole fork unit. It's still available from GM under the original part number of GM #3887177.
    • Jim K.
      • September 30, 2003
      • 64
      If your spring clip is broken you will have to buy a new clutch fork. Make sure you keep the old fork to compare with the new one.
      I have a 60 vette and ordered a new clutch fork from GM and it was not the same size. It turns out that on the 60 the rise was longer then on other models.
      A good machine shop can rivet your spring clip in place for about $10 or $20.
      • Rob A.
        • December 1, 1991
        • 2126
        I purchased a new clutch fork through GMpartsdirect.com. Decent price even including shipping.
        • Jim K.
          • 64
          I agree GM's price was much better that anywhere else I found.
          The only problem I had was that GM listed 58-62 as the same part and that wasn't true. The arm is a little longer (about 1/2 inch) on the rise. Sorry about confessing this situation.
