C1 1959 Thermostate - NCRS Discussion Boards
C1 1959 Thermostate
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12775
    C1 1959 Thermostate
    I've just replaced my water pump but I don't know where to position the delivered thermostate (160 degrees) ? Where should the thermostate be positioned ?
    greetings,
    Rob Musquetier.
    The Netherlands
    Rob.
    NCRS Software Developer
    • 43236
    Re: C1 1959 Thermostate
    Rob-----
    The "clock position" of the thermostat in the manifold makes no difference, at all. You can install it in any position.
    • Roy B.
      • February 1, 1975
      • 7044
      Under the thermostat housing ,thermostat first then gasket on top turned in any direction.
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12775
        Is the thermostate housing the metal part (with the two bolts) on top of the engine which connects the upper hose to the radiator ?
        greetings,
        Rob.
        Rob.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: C1 1959 Thermostate yes it is *NM*
          • Roy B.
            • February 1, 1975
            • 7044
            I don't mean to be mean . but are you puting me ON? You have a great looking Corvette!
            • Dave Suesz
              • Rob M.
                NCRS IT Developer
                • January 1, 2004
                • 12775
                Rob.
