bolt head markings - NCRS Discussion Boards
bolt head markings
  • Keith B.
    • December 1, 1991
    • 397
    bolt head markings
    I need some help on bolt head markings for the bolts that attach the rear cross member to the frame. My bolts were extremely rusted. I think it is RBS or something. I have seen cars use the "M" head mark as a replacement. Does anyone reproduce the correct bolt. I also would like to know what people are using to attach the front A arm to the frame through the nut plate. I have what to appears to be a double circle grade 8 --1 1/2 inch long bolts. What should I for replacement. I could reuse old bolts but I would like to go to a new bolt with the correct headmark.
    Keith Burmeister
  • Jeffrey C.
    • June 30, 1995
    • 53
    Re: bolt head markings
    What year Corvette are you asking about and is the suspension standard or optional?
    • Jeffrey C.
      • June 30, 1995
      • 53
      • Keith B.
        • December 1, 1991
        • 397
        This is for a 1967
        Keith Burmeister
        • Keith B.
          • December 1, 1991
          • 397
          This is for a 1967
          Keith Burmeister
          • Gene M.
            • April 1, 1985
            • 4232
            Keith,
            SBC are typically on the transmission and on the steering box. The M or WB or five line star, grade 8 bolts are typically securing the A arms at the nut plate. The rear cross member thru the donut is usually RBW or M. This does not eliminate other markings. I've only posted my exposures.
            • Gene M.
              • April 1, 1985
              • 4232
              Keith,
