c2 tail lights - NCRS Discussion Boards
c2 tail lights
  • Thomas C.
    • August 31, 2000
    • 133
    c2 tail lights
    I'm trying to install Trim parts repro tail lights on my 67 and they wont fit because of the gasket. Are correct gaskets available? Or how can the ones that I have be made to fit? Thanks, Tom
  • John M.
    • January 1, 1998
    • 813
    Re: c2 tail lights
    Tom, I installed these same tailights in my 67 with the gaskets. I pushed on the taillight from the outside while starting the speed nuts. Tightened a little bit over time and after a while got them all the way in. They are too thick, but it can be done.
      Re: c2 tail lights
      I installed a set a couple of months ago, with the gaskets that came on them, and had no problems; it helps to thread the nuts on and off the studs once before you install them so the nuts already have a place to "start".
