'58, Passenger hood release cable. - NCRS Discussion Boards
  • Terry leeker
    Having repaired several damaged areas on the firewall (ex-racer), 245 HP, SN 8490, I apparently have glassed over the thru hole location for the pass. side hood release cable. Could someone give me the location with two approximate reference diminsion point. Thanks
    • May 31, 1974
    • 8396
    Re: '58, Passenger hood release cable.
    Terry: if car apart(no firewall insullation attached) look on cockpit side of firewall for glassed over area. Otherwise , wait till a 58 owner responds to your post. good luck, mike
    • Terry leeker
      Unfortunately, I have the firewall insulation and all the heater stuff installed. I'ved pulled as much as I can without taking things apart. I don't know where to look.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Terry - 1958 - 1960 NCRS National Team Leader should be able to help with specific information. Tim Mickey's contact info should be in Restorer.
        • Terry Leeker
          Thanks for the response, Dennis. I'll give Tim a call.
