C3 '70 LS5 Oil Pan - NCRS Discussion Boards
C3 '70 LS5 Oil Pan
  • jim34671
    C3 '70 LS5 Oil Pan
    For those with the true original pan,..where is your drain plug located?
    Forward,left,right or aft?
    Happy TGD.
    • 43221
    Re: C3 '70 LS5 Oil Pan
    Jim----
    All original Corvette big block oil pans, and there were 4 different part numbers used over the 65-74 period, have the drain plug located on the rear left lower surface. As a matter of fact, there were only minor differences in the pans used in PRODUCTION and these minor differences did not include any change in the oil drain plug mounting.
    Big block pans used for other Chevrolet chassis applications may have the oil drain at other locations. Some of these, I know have the drain on the side. I believe that most of the passenger car pans will fit a Corvette chassis but I don't think that the Corvette pan will fit most passenger car chassis.
    • jim34671
      Joe,
      Mine's located aft 6 o'clock..just close up against bell housing.
      Original as far as I know.
      Rgds
        • 43221
        Jim-----
        Yes, that's the general location I'm talking about. It will be just forward of the bellhousing inspection cover (so that when you remove the drain plug the oil hits the cover as it drains). The drain plug should be well left of center on the pan, though.
        • jim34671
          Joe,
          My plug is dead center on the back side of pan...not left,not right.
          Jim
            • 43221
            Jim------
            Is the bottom of the pan's sump almost completely flat, with just a little protrusion near the oil drain, OR is there a "V" shaped protrusion which extends back from the oil drain area to the "point" of the "V" about 2 inches back from the rear of the pan? If it's present and you look straight up at the bottom of the pan's sump, you will see the "V" shaped configuration.
