1957 radiator tag - NCRS Discussion Boards
1957 radiator tag
  • Mike Noguera
    1957 radiator tag
    FOR A 1957 Corvette-
    Does the RADIATOR tag go (welded on) in the middle of the upper tank, facing the engine?
    Does it get centered between the WATER INLET and the left edge of the tank? (facing forward from the driver's side)
    Thanks in advance,
    Mike
  • Dave Suesz
    Well, if my 55 is the same...
    It is SOLDERED to the middle of the upper tank, facing the engine.
    • Verle R.
      • March 1, 1989
      • 1163
      Re: 1957 radiator tag
      The radiator tag on my 57 has the tag sodered near the middle of the top tank facing the engine.
      Verle
      • Mike M.
        • May 31, 1974
        • 8383
        Both my 57s and my 55 and my 56 are just like Verl describes. mike
        • Roy B.
          • February 1, 1975
          • 7044
          My 55 is also the same as Mike's but it also has a little tag soldered next to it with a V stamped in it . ??? Original Radiator.
