67 TACHOMETER CABLE - NCRS Discussion Boards
67 TACHOMETER CABLE
  • Rob A.
    • December 1, 1991
    • 2126
    67 TACHOMETER CABLE
    The outer housing is original and in perfect condition, but I would like to replace the actual inner cable if it is available. It measures about 24".
  • William C.
    • May 31, 1975
    • 6037
    Re: 67 TACHOMETER CABLE
    Use a speedometer cable repair kit to fabricate the new cable, same thing.
    Bill Clupper #618
    • Mike M.
      • May 31, 1974
      • 8385
      Any AC Delco dealer can supply the inner cable and ends to fabricate new one. good luck, mike
      • Frank H.
        • May 22, 2013
        • 148
        Gm parts direct tach cable #6480367 $16.46
        anyone seen one?
        • Richard D.
          • December 1, 2002
          • 328
          I bought a speedo cable repair kit (inside wire) from NAPA for about $9.00 or so. They had a couple in various lengths in stock.
          You insert the inner wound wire from the speedo side, seat it, cut the terminal end off to the proper length, and crimp on the drive end.
          FYI,
          Rich
