nuts and bolts - NCRS Discussion Boards
nuts and bolts
  • andy pilsworth
    nuts and bolts
    Does anyone know of an easy reference chart for the part numbers for the various nuts and bolts on the suspension/chassis. Our "helper" threw all the bolts in the garbage and AIM only shows the part numbers. Any ideas?? 63 vette
    Andrew
    • 43240
    Re: nuts and bolts
    Andy---
    This question has come up numerous times in the past. I think you'll find some info in the archives. However, the quick answer is that there exists no such single and comprehensive reference source. You can use information from the Paragon bolt chart/poster, information found in the Vette Vues Fact Books by M.F. Dobbins, and the "Chassis Restoration Guide" by Joe Tripoli. The latter 2 books can be purchased from the NCRS Bookstore. The Paragon wall chart can be purchased from Paragon for a nominal cost.
    • Kent K.
      • December 1, 1982
      • 1139
      Re: nuts and bolts
      You have email.
      Kent
      NCM Founder - Member #718
