1st Gear - NCRS Discussion Boards
1st Gear
  • Randy Adams
    1st Gear
    I'm talking on the phone with someone doing some transmission work for me. He is calling something the 1st. gear slider. Is this the same as a shifting fork or something totally different? It's for a '64/4spd muncie. He's telling me the slider is discontinued and to try to find an old tranny parts place. If it is a shifting fork I can get it from ZIP. The term is not familiar. Any help is appreciated.
  • Paul E. Young
    Re: 1st Gear
    Try George at A-1 Transmission in Denver. His number is 303-623-1401. Tell him Paul Young referred you. Paul P.S. A slider is what the fork connects to.
    • Gary B.
      • February 1, 1997
      • 7033
      I'm sure Ed Harnett can help you with parts
      Randy,
      I think Ed Harnett should be able to get any used part you need. His contact info is:
      Ed Hartnett's 4 speeds
      242 Pembroke Ave
      Lansdowne, Pa 19050
      610-623-9381
      EH4Speeds@aol.com
      Gary
        • 43240
        Re: 1st Gear
        Randy-----
        The "slider" is the outer component of the synchronizer assembly. In this case, it must be the 1-2 syncro slider that's bad.
        The "slider" has never been available from GM as a seperate piece. However, they've been available in the aftermarket for years. Mr. Gasket used to sell them and I believe that they still do. Also, complete synchro assemblies are available now as manufactured by Masiero, S.A. in Italy (Masiero is the largest manufacturer of gears in the world, so don't let anyone tell you that the Italian gears are "no good").
        I'm sure that any of the 2 sources mentioned can fix you up with either a new "slider" or a new complete synchro. I wouldn't use a used slider unless there was no other alternative.
        • John M.
          • January 1, 1998
          • 813
          Re: 1st Gear
          Try 5speeds.com. I got a slider from them for $40
          • Randy Adams
            Re: 1st Gear : Thanks
            Many thanks guys.I have e-mails & messages out to these contacts. I'm sure all will be well now."NCRS is great"
            Randy
