66 Holley List 3370 - NCRS Discussion Boards
66 Holley List 3370
  • Brian J.
    • August 31, 1999
    • 70
    66 Holley List 3370
    I have an original Holley List 3370 Part #3882835 EO. The carb is not on the car. I bought it restored about 5 years ago. It has metering bodys on the primary and the secondary side. They are both #4976 correct for the 3370, I know they only came with metering bodys on the primary side only. My question is it possible to remove the metering body from the secondary side and put the carb back the way it is supposed to be? Any help will be appreciated.
    Brian 32829
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 66 Holley List 3370
    you need a shorter fuel transfer tube,secondary metering plate # 34R2007-8,which is not serviced anymore and correct gaskets. the correct metering body is 4796.
    • Brian J.
      • August 31, 1999
      • 70
      Clem,
      Could this be easily done by a carb restorer? Will they have the correct parts? Any recommendations?
      Brian
      • Clem Z.
        • January 1, 2006
        • 9427
        brian i sent you a private e mail.
