T Q Front Spindle Inspection Marks - NCRS Discussion Boards
  • Jerry Clark
    It has been a long standing debate here, (my Shop);
    The Quanta detail instructions, (allowing for this companies inaccuracies) clearly shows the spindle painted, (dipped) orange on BOTH ENDS
    The JG is unclear
    Opinions regarding these marks would be appreciated before I complete the front suspension assembly
    Thank You
  • John M.
    • January 1, 1998
    • 813
    Re: T Q Front Spindle Inspection Marks
    Jerry,
    I have a picture of an original 67 spindle which I think shows both ends being orange. There's a lot of rust present but it looks like there's paint on both ends. I'll email you the picture tomorrow.
    • John Daly
      When I degreased the front end on my early 67 the orange paint was evident as a 6 to 8 inch smear halfway between the ends as though it was slapped with a paint brush. Both sides looked about the same. No evidence of dipping at each end.
      JD
      • mikemccagh
        Jerry: have done aboutr 8 mid-years and most spindles had orange at both ens, sone had it centrally and some had it on just one end. never seen one totally oranged-out. regards, mike
        • Jerry Clark
          Thank you all;
          I have already painted both ends as I have in the past, I sent out some "pick it apart" pictures and the jury was out on which way was correct
          jer
          • Tim E.
            • April 1, 1993
            • 360
            This photo is of my 1966 front spindle assembly. It's pretty easy to see the extent of orange paint coverage on the bottom (appears to be dipped). Only remnants remain on the upper part, but orange paint can be seen.
            • Tim E.
              • April 1, 1993
              • 360
              Missing photo from previous response:
                No pic - try removing the question mark after ".jpg" in the URL.
                • Tim E.
                  • April 1, 1993
                  • 360
                  Thanks John. Still having trouble so I'll try this link to the missing photo from previous post....
                  • Kevin M.
                    • November 1, 2000
                    • 1271
                    Tim,
                    Your first post picture worked fine for me?
                    Hollywood
                    • Chuck S.
                      • April 1, 1992
                      • 4668
                      Orange inspection paint marks are also found on early C3 spindles.
                      I could be wrong, but I doubt they were dipped. Mine were large, irregular marks that were painted, more like daubed with like a 1" diameter round brush, and only to the center portion of the spindle. There were also smaller "white" crayon inspection marks on each end where the ball joint studs were installed.
                      • Ronnie Robertson # 36786
                        Re: Photo of 1966
                        Jerry,
                        Here is a photo of my 1966. There is red smeared over the lower 1/3, and white on the bottem end! Others are available if you are interested.
                        Ronnie
