67 BB CORRECT ENGINE GASGETS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Is anyone aware of a complete engine gasget set available that would include the "correct" ones that are visible after installation, or should I buy a standard set, like felpro, and replace those that are looked at during judging?
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 67 BB CORRECT ENGINE GASGETS
    Rob, Make sure you get steel shim head gskt, cork valve cover, paper intake and water pump. Nix the exhaust manifold gskts.
    • Mike M.
      • May 31, 1974
      • 8396
      Intake to case rubber seals are judged. rubber tab protruding for and aft have small GM embossed in the rubber tab. Only source i know of is NORS GM Gasket sets--Swap meet material. good luck, mike
