60 Window drip moulding - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    This probably seems silly, but my glass installer has the window parts only and my painter has all my books. The orientation of the drip moulding on the bottom of the glass looks obvious. I would like to varify it before he installs the glass.
    Pictures I see are not clear. Can somebody give me a good discription.
    I think the "water catch side" and cut out goes toward the "roller" side.
    I assume the catch goes out but he's not even sure wich window is left or right.
    Larry
  • Mike E.
    • February 28, 1975
    • 5139
    Re: 60 Window drip moulding
    Larry--
    I'm assuming that you're talking about the rubber drip molding--if so, the trough side goes to the outside of the window--rain hits the car from the outside, then is kept from hitting the regulator, etc. below by this tpugh.
    Windows---stainless surround attaches on the bottom to a piece that extends the length of the bottom of the window. That piece has the roller to the outside, with the notches for the lower window track facing to the inside. The track is fastened to that by screws that go from the inside of the door through the track into the channel that is behind (outside) of that.
    • Larry P.
      • June 30, 1999
      • 481
      Thanks Mike, that's what I needed. *NM*
