C2 FRT FENDER WIRE HARNESS CLIP - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    It appears from the assembly manual that the wire harness clips on the front of the inner fenders (one on each side) are attached with flat head rivets inserted from the inside, with a washer on the clip side. Is this correct?
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C2 FRT FENDER WIRE HARNESS CLIP
    by posting the year you vette was produced will enble us to respond to your questions.regards.mike.
    • Rob A.
      • December 1, 1991
      • 2126
      I'm working on a '67, but I would imagine it would be the same installation for all C2 cars.
      • Wayne W.
        • April 30, 1982
        • 3605
        I assume that you are talking about the one on the front, behind the grille opening near the park lamp wire connector. The answer for your application is yes. You may find 63s with the clip glued on.
        • Rob A.
          • December 1, 1991
          • 2126
          Thanks...
