I'm replacing the incorrect Muncie transmission in my '62 with a correct T10. The shifter will be a Hurst with the stock appearing handle. The handle is removable from the shifter body.
Can I install the transmission with the shifter body and the rods in place? The handle will be bolted in later from above. The rear mount will be out of the way. (Built the John Hinckley "saddle" yesterday. Looks like it's going to work great.)
