'Natural' finish and surface protection - NCRS Discussion Boards
  • Todd H 26112
    THe recent mention of driveshaft finishes sorta begged a question I've had for a while in the back of my mind. Beit driveshafts in early C3s or whatever - there are those pesky parts that are supposed to have 'natural' finish.
    Let's set aside exhaust stuff - what about the other items that may develop surface rust and so forth over time w/o some sort of paint?
    My strong preference is to paint or whatever anything rather than leave it exposed regardless of whether it's correct. It won't fool anybody but what are some recommendations for paints etc. The only thing that quickly comes to mind is something in a shade like 'cast blast' perhaps to perhaps 'approximate' natural metal finishes.
    I'd be curious to hear what various folks do who prefer not to leave metals exposed incorrect though it may be.
    thanks,
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 'Natural' finish and surface protection
    Todd - in some cases, I have found Krylon's satin finish clear to be a decent choice, if applied/dusted lightly it looks more original than the paint choices. For instance, after bead cleaning a rear end housing, letting it "age" a bit to rid it of that just bead blast look, followed by the Krylon. Much nicer than cast blast, and a natural cast look. I don't know how a driveshhaft or halfshaft tube would fare with this approach, but I thought I would try it....Craig
    • Harmon C.
      • August 31, 1994
      • 3228
      Todd If the drive shaft has 5 points you will lose a point or two for finish. The half shafts may have 8 points so you would loose 2 or three. This is what I lost when I painted them. Lyle
      Lyle
      • Chuck S.
        • April 1, 1992
        • 4668
        Todd, some people say leave it raw, and continuously treat it with "Pre-Lube 6". Like you, I am not one to be setting myself up for constant maintenance...forget it too long, and you have to start over.
        Some people say that "Cast Blast" will work; frankly, after watching a few chassis judgings, I don't think any opaque paint will fool judges. You can use it, you won't have rust, but it will probably cost you during judging. It's your choice...rust, Or, take your chances. The points lost may be worth not having to deal with rust.
        One other option to consider is misting a light coat of flattened clea (near fully flat, just a little gloss). If you get it too wet or too glossy, it will definitely look painted. One dry coat might avoid deducts; haven't tried it for judging, but I'm "ruminating" on it.
        • Kevin M.
          • November 1, 2000
          • 1271
          Move to California we don't rust out here.
          Kevin
          • Jerry Clark
            I HATE RUST
            I have a powder coat guy, (yeah, I know, fate worse than death), that will apply a flat clear as lightly covered as is possible. I bring the parts, Differential housing and most cast pieces, back and dust them with glass beads to further flatten whatever sheen may remmain. NO, they do not look "raw" but damned close and like others, I allow the cast pieces to oxidize slightly before PCing
            jer
            • Al S.
              • June 30, 2002
              • 73
              I've used "stainless steel" on a daily driver. By all means no coating is correct but I happen to favor that one ovet cast blast on some parts.
              '72 Top Flight Coupe
              • Dave K.
                • November 1, 1999
                • 952
                I've used Krylon satin clear on my bead blasted 66 rear end case, half shafts, driveshaft, ball joints and all other natural finish parts. It has held up reasonably well.
                Dave Kitch
                33108
                • Dick W.
                  • 10483
                  No rust, just burn up or shake apart
                  Dick Whittington
                  • John A.
                    • August 31, 2002
                    • 172
                    Eastwood has a satin finish clear for coating natural finish parts. I have had problem with parts rusting under the finish after it was applied though. I've tried heating the part before the paint application to remove any remaining moisture and it seems to help. I'll have to try the Krylon product to test for better results.
                    • Harmon C.
                      • August 31, 1994
                      • 3228
                      John A little rust might just make it appear more original in NCRS circles. Lyle
                      Lyle
