Right Cylinder Head Plug - NCRS Discussion Boards
  • Lawrence Berte
    Does a 1970 300HP 350 use an indented hex, indented square, or external square pipe plug on the right cylinder head to plug the unused temp. switch hole.
  • Chuck S.
    • April 1, 1992
    • 4668
    Not Unused...
    Lawrence, the right cylinder head has a dedicated temperature switch for the "transmission controlled spark" system.
    • Lawrence Berte
      Re: Not Unused...
      Interesting, thanks for the information Chuck. I'll get on it first thing in the morning. Lawrence
      • Chuck S.
        • April 1, 1992
        • 4668
        Re: Not Unused...
        TCS temperature switches are available from most Corvette vendors; Paragon and Dr. Rebuild are two that I know have them. I believe these were manufactured by AC, but I am not sure they are identical to the originals. If there are obvious differences, they may incur deducts in judging.
          • 15600
          Re: Not Unused...
          If all the spark plug shielding is in place the TCS temperature switch is all but invisible on a 1970-72 small block. However, on a big block it's very visible.
