56-57 differential? - NCRS Discussion Boards
56-57 differential?
  • Mike E.
    • February 28, 1975
    • 5139
    56-57 differential?
    Casting number of this rear end appears to be 3747506. There is no casting date in the usual place (or in an unusual place, for that matter!) It's a 3.70 open, with a stamped code of AH 7 21 My 56-7 judging manual is on loan, so if this is covered there I apologize. Do I recollect correctly that the 56 didn't necessarily have a casting date? Would this then be a late 56/early 57 rear? The July 21 stamping, with the AH code, leads me to suspect that? Wrong? Faulty? I'd appreciate input.
  • Jimmy B.
    • July 31, 1980
    • 584
    Re: 56-57 differential?
    Mike,
    Check that casting again, I believe 56's end with 306. I've seen cast dates as early as K of 55 so I am wondering if this is a July 55 rear end?
    Jim Blakely
    • James F.
      • December 1, 1985
      • 596
      Mike,
      Jimmy is correct, you should be seeing a 306. On mine, right below these numbers is a molded date code which includes the year (single digit). AH stamp sounds good to me regarding a 3.70. Incidently, you have a heavy package coming your way! Alert your wife ;-) ! Regards,
      • Mike E.
        • February 28, 1975
        • 5139
        On closer examination, it is 3747306! That is followed on the same line by the "GM" casting, and then immediately behind the GM, on the same line, is a 5.
        Does that bear out Jimmy's July 55 hypothesis?
        • James F.
          • December 1, 1985
          • 596
          Mike,
          I belive this is the pattern number. Mine has a 14. Regards
