C2 Fan clutch - NCRS Discussion Boards
C2 Fan clutch
  • Jerry S.
    • May 31, 2003
    • 145
    C2 Fan clutch
    Does anyone recogize the following part # 27112414. Is this a GM fan clutch or a replacement?
    • 43238
    Re: C2 Fan clutch
    Jerry----
    I show no record of any such part number in the GM parts system.
    • Jerry S.
      • May 31, 2003
      • 145
      Re: C2 Fan clutch
      The only company I know of making fan clutches for GM was Eaton. It must be one of their process numbers. The item is on e-bay and the price is good for a working clutch.
        • 43238
        Re: C2 Fan clutch
        Jerry-----
        There were at least 3 suppliers to GM for fan clutches in the "old days". One was Eaton. Another was Sweitzer Clutch. A third was Delco which made some of their own fan clutch models. Eaton and Delco usually have a coil-type thermostat; Sweitzer uses a "bi-metallic" plate.
        Eaton still supplies fan clutches to GM. I don't think that Sweitzer or Delco supply fan clutches to GM anymore. However, there may be other suppliers that do.
        • Joe R.
          • July 31, 1976
          • 4551
          Re: C2 Fan clutch
          Jerry,
          Until recently GM serviced the fan clutch under P/N 3916141 made by Eaton. It is an acceptable replacement and most judges don't know the difference or let it slide since the cost of rebuilding a fan clutch is astronomical. You might want to check with your Chevy dealer and see if any of the fan clutches are still in the system. The cost was $142.88 dealer and $190.50 list.
          JR
            Re: C2 Fan clutch
            Cost to restore an original fan clutch isn't astronomical.... Fred Oliva's fee is nicely between the figures you quote for the GM service replacement component!
            • Craig S.
              • June 30, 1997
              • 2471
              Re: C2 Fan clutch
              Still available at gmpartsdirect.com for $108.59 + $21.72 shipping....Craig
