Trailing Arm Differences, 65-7 - NCRS Discussion Boards
  • Dan A.
    • May 31, 1974
    • 1074
    I've heard there is a difference between the reproduction trailing arms and originals. What is the difference?
    • 43221
    Re: Trailing Arm Differences, 65-7
    Dan-----
    There were actually several different trailing arm sets used over the 65-82 period. Each was slightly different than the others but all are, basically, interchangeable. The last "iteration" was GM #14035663 and 14035664. These parts are still available from GM and are, I believe, what are currently sold as "reproductions".
    The 14035663 and 14035664 incorporate changes made for the 1978-82 model years and changes made for the 1982 model year. I don't know what the changes were that were made for the 1978 model year, but they may have been related to the configuration/attachment point of the parking brake cable guide and/or the configuration of the control arm bumper brackets. The change made for 1982 included the addition of 4 drilled and tapped holes surrounding the large bearing support opening in the rear of the trailing arm. These holes are for attachment of the plastic u-joint shields used for the 1982-only model year.
    So, I expect that the above differences are what will be found in the "reproduction" trailing arms. As far as I know, the reproductions are either the GM pieces or, at the least, reproductions of the last iteration of the GM part.
    • Gary B.
      • February 1, 1997
      • 7024
      Plus the rear sway bar holes
      Dan,
      Almost all of the new GM and repro T-arms that I've seen for sale these days already have the two holes drilled for mounting a rear sway bar. One can weld these up and grind the weld to make it look like they were never there.
      Gary
